3CX connection to Nokia E61i
Discussion in '3CX Phone System - General' started by aguy48, Dec 22, 2007.
  1. aguy48
    Dec 22, 2007
    Hello Friends,
    I have the Nokia E61i and use sipgate voip services perfect, but I can't connect with 3CX. Somebody know the 3CX SIP parameter to it.
    Thanks,
    Alex Guy
  2. Aikon
    Dec 7, 2007
    7
    I tried to configure my E61 following this post:
    http://www.3cx.com/forums/viewtopic.php?t=1488
    It seems to be the right way to configure the internal Nokia sip client, but I did not get the voip client working.
    Aikon
