3cx connetion problems (request timeout)
Discussion in '3CX Phone System - General' started by netural, Jul 30, 2007.
  1. netural
    Jul 30, 2007
    15
    hello,
    i try to get my 3xc installation working, cause we want move in our company from normal calling system to 3cx ip calling system.
    i tried 2 different provider (sipgate, sipcall) but both dont work with my configuration.
    i named my external ip adress directly cuz i had an "couldnt resolve ip adress error", but now it also dont work.
    the port 5060 is successful forwarded and open (i tried to access iis temporarely on that port from external and that worked) - so i dont have any idea what else i could do.
    are there any other ports i have to forward/open for the pure registration process?? atm i only care about 5060.
    i get following error messages:
    12:36:27.584 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:27.584 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:36:26.647 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:26.647 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:36:25.756 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:25.756 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:36:25.443 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:25.443 ClientRegs::eek:nFailure [CM113006] Registration of sip:9664385@sipgate.de has failed; reason=Request Timeout
    12:36:23.803 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:23.803 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:23.787 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:23.787 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:23.787 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:23.787 ClientRegs::eek:nFailure [CM113006] Registration of sip:9664385@sipgate.de has failed; reason=Request Timeout
    12:36:22.521 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:22.521 ClientRegs::eek:nFailure [CM113006] Registration of sip:9664385@sipgate.de has failed; reason=Request Timeout
    12:36:22.209 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:22.209 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:36:20.943 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:20.943 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:20.928 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:20.928 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:20.912 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:20.912 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:20.896 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:20.896 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:20.881 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:20.881 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:20.818 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:20.818 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:36:20.490 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:20.490 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:20.162 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:20.162 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:20.146 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:36:20.146 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:36:16.052 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:16.052 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:14.177 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:14.177 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:14.162 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:14.162 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:14.146 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:14.146 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:10.677 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:10.677 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:10.662 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:10.662 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:10.646 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:10.646 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:10.630 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:10.630 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:10.615 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:10.615 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:09.615 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:09.615 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:04.302 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:36:04.302 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:36:04.286 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:36:04.286 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:36:04.271 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:36:04.271 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:36:04.255 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:36:04.255 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:36:02.646 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:02.646 ClientRegs::eek:nFailure [CM113006] Registration of sip:9664385@sipgate.de has failed; reason=Request Timeout
    12:36:02.646 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:36:02.333 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:02.333 ClientRegs::eek:nFailure [CM113006] Registration of sip:9664385@sipgate.de has failed; reason=Request Timeout
    12:36:02.021 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:02.021 ClientRegs::eek:nFailure [CM113006] Registration of sip:9664385@sipgate.de has failed; reason=Request Timeout
    12:36:02.021 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:36:01.396 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:01.396 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:36:00.770 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:36:00.770 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:35:59.786 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:59.786 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:59.770 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:59.770 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:57.567 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    12:35:57.567 ClientRegs::eek:nFailure [CM113006] Registration of sip:43720515615@212.117.200.148 has failed; reason=Request Timeout
    12:35:55.364 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:55.364 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:53.786 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:53.786 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:53.458 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:53.458 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:53.130 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:35:53.130 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:35:53.114 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:35:53.114 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:35:53.098 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:35:53.098 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:35:53.083 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:35:53.083 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:35:53.067 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:35:53.067 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:35:53.051 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:35:53.051 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:35:51.661 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:35:51.661 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:35:50.317 ExtLine::Register [CM110004] Send registration for <sip:9664385@sipgate.de>
    12:35:50.317 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10001' device='SIPGATE'
    12:35:49.973 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:49.973 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:49.958 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:49.958 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:49.942 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:49.942 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:49.926 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:49.926 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:48.614 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:48.614 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:48.598 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:48.598 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:48.582 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:48.582 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:48.567 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:48.567 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
    12:35:48.551 ExtLine::Register [CM110004] Send registration for <sip:43720515615@212.117.200.148>
    12:35:48.551 ExtLine::Register [CM110002] Use Specified IP for device line registration DN='10000' device='SIPCALL'
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    If you have "couldnt resolve ip adress error" -- this means, that port 5060 IS NOT forwarded correctly, or you have a symmetric NAT. 3CX can not work behind symmetric NAT, and I suppose even providing specific IP for registration wouldn't help in this case.
  3. netural
    Jul 30, 2007
    15
    what is symetric nat? we have a server/gateway with one official ip adress (what is all userss external ip) and every user have a internal ip adress. the ip of server on which the 3cx service is running is used for the port forward of 5060 UDP/TCP. And the forword work definitely, cuz when i use 5060 for any other service like webserver it work perfect.
    so... :)
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    No, webserver won't fit. You try to connect with SIP phone :)
    I did. And what did I see? Sip Express router meets me there and refuse registration. So, I didn't get to 3CX PBX. It may be a cause of problem.
    Symmetric NAT makes binding IP:port <-> IP:port, and for each IP on remote end it will make different port mapping on local end.
  5. netural
    Jul 30, 2007
    15
    i cant follow your answer. internal connects work, 3 testuser are connected with their ip phone to the 3cx software. but the 3cx software can not connect with a sip service provider like sipgate.
    tahs my problem
  6. netural
    Jul 30, 2007
    15
    now i rebooted the server, and it seems he dont connect. i dont know why, the SIP Provider is in the system but he dont try to register.
    all what happen is following:
    14:00:06.655 ServRegs::eek:nAdd [CM113002] Registered: Ext.035
    13:56:08.935 ListenConnect [CM114000] SL: connected NLNZ3CX1:0/PHPExtension_0 at [NLNZ3CX1]/PHPExtension_0
    13:49:06.953 ListenConnect [CM114000] SL: connected NLNZ3CX1:0/VoiceBoxManagerService at [NLNZ3CX1]/VoiceBoxManagerService
    13:49:05.562 MediaServerConnected [CM112000] Media Server is connected
    13:49:05.562 ListenConnect [CM114000] SL: connected NLNZ3CX1:0/MediaServer at [NLNZ3CX1]/MediaServer
    13:49:05.046 CallMgr::Stack::thread [CM106001] ** Enter Stack Loop **
    13:49:05.031 CallMgr::DumThread::thread [CM100004] ** Enter DUM Thread **
    13:49:05.015 DBA [CM109000] ** Database connection Ok **
    13:49:04.984 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
    13:49:04.984 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
    13:49:04.984 CallMgr::Initialize [CM100002] Default Local IP address: 10.28.200.50:5060
    13:49:04.890 IVRConnected [CM111000] IVR Server is connected
    13:49:04.890 ListenConnect [CM114000] SL: connected NLNZ3CX1:5483/IVRServer at [NLNZ3CX1]/IVRServer
    13:49:04.640 CallMgr::Initialize [CM100001] Version: 3.0.2328.0
    13:49:04.640 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
    13:49:01.546 LoadLicenceInfo [CM100008] Licence loading error
  7. archie
    3CX Support
    Aug 18, 2006
    1,299
    I think here's the problem. You have Sip Express router installed on that server. And I suspect it fiddles with SIP packets it receives. You should set it up correctly, or disable it (at least to check).
  8. netural
    Jul 30, 2007
    15
    uhhhhhhhhhhh .... ^^
    what is sip express router? and how can i disable it? OO i just installed the standard installation of 3CX and added the provider and few clients for test.
    but how can it be that now no error appear and it still dont work? it just dont register? oo
    and btw how u could u know if i have SIP EXPRESS ROUTER installed? i didnt post my ip here O.O
  9. archie
    3CX Support
    Aug 18, 2006
    1,299
    Isn't it your IP: 212.117.200.148??
    If not, than I actually don't know about your system. I've just tried to connect to it with SIP phone and see responces, and responses was from express router, not 3CX.
  10. archie
    3CX Support
    Aug 18, 2006
    1,299
    Yeah, I'm sorry. It's my fault, by some reason I thought that is your IP, but it isn't, I see now.
    So, than I suggest to try and set up STUN resolution for your 3CX system.
  11. netural
    Jul 30, 2007
    15
    STUN only resolve the external ip? then its same when i just type it manual in the system. but i still get the same error.
    pah, i will try another system - maybe its just not compatible. anyway thanks for your help!
  12. archie
    3CX Support
    Aug 18, 2006
    1,299
    No, STUN not only resolves IP, but also port mapping. If it can not resolve it - there's no way to connect VoIP provider.
    For quick check you may use any softphone to set up with some VoIP account and try to register it and call from it without involving 3CX.
  13. archie
    3CX Support
    Aug 18, 2006
    1,299
    BTW, try to ping STUN server you're using from the console. May be it just not running atm.
  14. netural
    Jul 30, 2007
    15
    i tried now different stun servers. there appear no error that that stun servers dont work, but it seems he cant resolve ip. but why no error then? all ports for stun are definitely open and forwarded. TT
    14:54:32.281 ExtLine::Register [CM010002] Line DN='10000' device='sipgate' can not be registered. External IP isn't resolved.
    14:54:32.281 ExtLine::Register [CM110001] Use External IP for device line registration DN='10000' device='sipgate'
    14:54:31.874 ListenConnect [CM114000] SL: connected NLNZ3CX1:0/PHPExtension_0 at [NLNZ3CX1]/PHPExtension_0
    14:54:18.499 ListenConnect [CM114000] SL: connected NLNZ3CX1:0/VoiceBoxManagerService at [NLNZ3CX1]/VoiceBoxManagerService
    14:54:18.499 IVRConnected [CM111000] IVR Server is connected
    14:54:18.499 ListenConnect [CM114000] SL: connected NLNZ3CX1:5483/IVRServer at [NLNZ3CX1]/IVRServer
    14:54:17.890 CallMgr::Stack::thread [CM106001] ** Enter Stack Loop **
    14:54:14.499 MediaServerConnected [CM112000] Media Server is connected
    14:54:14.499 ListenConnect [CM114000] SL: connected NLNZ3CX1:0/MediaServer at [NLNZ3CX1]/MediaServer
    14:54:14.437 CallMgr::DumThread::thread [CM100004] ** Enter DUM Thread **
    14:54:14.421 DBA [CM109000] ** Database connection Ok **
    14:54:14.390 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
    14:54:14.390 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
    14:54:14.390 CallMgr::Initialize [CM100002] Default Local IP address: 10.28.200.50:5060
    14:54:14.233 CallMgr::Initialize [CM100001] Version: 3.0.2328.0
    14:54:14.233 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
    14:54:14.218 LoadLicenceInfo [CM100008] Licence loading error
  15. archie
    3CX Support
    Aug 18, 2006
    1,299
    Really strange. Try to look into 3CXPhoneSystem.trace.log.
    Also, check your settings for 'Timeout time for STUN response (ms)' in General settings/STUN server options.
  16. netural
    Jul 30, 2007
    15
    timeout is: 2000
    and in that log appear nothing about stun or sipgate :(
  17. archie
    3CX Support
    Aug 18, 2006
    1,299
    I don't know, it never happens before. May be you should try to reboot the PC.
