3cx Console management logout automatically
Discussion in '3CX Phone System - General' started by compumax, Sep 22, 2011.
  1. compumax
    Sep 22, 2011
    I install 3cx V10 (Free version) in my windows 7 computer and it working fine. When the computer is idle, the console management log out automatically. I want to know how to resolve this problem.
    Emilthon
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    This isn't a problem. If you go idle it logs you out, this is by design. If you log into your banks web interface it logs you out after a set idle time. You are probably using the web management console which does this. If you use WIN Forms it will not.
    Thanks,
    Nate
