3cx could work in UAE?
Discussion in '3CX Phone System - General' started by Malai, Mar 7, 2018.
Tags:
  1. Malai
    Mar 7, 2018
    Dear 3cx,
    Just i want to know, 3cx VoIP could work in uae.
    In uae VoIP calls are banned. So that i am asking.
  2. StefanW
    Jun 2, 2009
    1,222
    93
    not all usage in the UAE is regulated but some is, for your case I think it would be best to get in touch with our local distribution @ http://sitec.ae/solutions/3cx/
  3. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    If you can use traditional phone lines, 3CX does support using gateways that connect to traditional POTS / PRI / BRI lines. You are not limited to just SIP trunks.
