3CX CRM API**COMING SOON
Discussion in '3CX Phone System - General' started by mbaum, Jun 3, 2011.
  1. mbaum
    Feb 25, 2011
    We was create our own CRM Plug In for 3CX V9, following the blog at http://www.3cx.com/blog/docs/crm-api/.
    Is there a description for new API, coz how is look the old one is not function with the new V10? I like to move on V10, but for this we need our CRM Plug In back to work.
    Thanks for help.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    Re: 3CX CRM API
    contact me nb@3cx.com and I will send you a preliminary document of what is going to happen in V10 once CRM is released.
  3. ccalza
    Jun 23, 2011
    11
    Hi, I'm also interested about CRM API and v.10
  4. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    We will updating the documentation on the CRM API sometime next week with the release of the CRM Integration.
    Details will be available via the blog.
