3CX CRM API
Discussion in '3CX Phone System - General' started by centro1, Jun 13, 2013.
  1. centro1
    Dec 3, 2012
    9
    i am developing a plugin for a CRM application. I am using 3CX CRM API following instructions at http://www.3cx.com/blog/docs/crm-api/ .
    Anyway i am having big problems in finding the right usage of each method exposed by the TCX.CRM dll .
    Can anyone provide some additional info about the object usage?
    Thank you very much.
  2. centro1
    Dec 3, 2012
    9
    Just a useful tip for the example plugin (you can download it from the page http://www.3cx.com/blog/docs/crm-api/)
    1)At the time of this writing the target framwork is .NET 4 (not .NET 2 as mentioned).
    2)You MUST compile, then copy and rename "Plug-in Sample.dll" to "Plug-in Sample.resources.dll" and move it to "C:\Program Files (x86)\3CX CRM Integration", wich is the parent folder of the plugin target folder. Otherwise, the sample plugin contains a bug and it will not work.
    The help desk told me that with 3CX version 12, it will be corrected (providing a new example plugin).
    Thank you.
