3CX CRM plugin for v14
Discussion in 'CRM / Helpdesk / App Integration' started by pittas, Mar 28, 2017.
  1. pittas
    Mar 28, 2017
    We are interested to know if there is a way to use the CRM Plugin we developed for 3CX v15 for with v14 Pro.
    Thanks.
  2. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
    Hello there,
    Unfortunately you are able to develop the CRM Plugin only in 3CXPhoneSystem Version 15.
    If you are still interested to develop a CRM Plugin you can upgrade your PBX to Version 15 and you can use our 3CX Visual Studio Template to help you develop the plugin. You can read our blog post for the 3CX Visual Studio Template from here.
    Regards,
    Xanthi Zachariou
  3. pittas
    Mar 28, 2017
    Is there a way to develop a plugin for v14 Pro ?
  4. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,078
    77
