3CX CRM V12 Tapi driver
Discussion in '3CX Phone System - General' started by 805tech, Oct 18, 2013.
  1. 805tech
    Aug 30, 2013
    39
    I am trying to install the TAPI driver for CRM integration on XP and it gives a error when it tries to register it. Anyone else having this problem?
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    733
    112
    Haven't tried since XP isn't supported in V12. Best of luck to you.
  3. filipvds
    Apr 15, 2013
    33
    we also have a problem with the tapi driver.
    When I dial a number from our external application, dialer.exe from microsoft starts with an error message: "there was an internal error. please try again".
    We don't close dialer.exe and we try again, and it works.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,097
    141
    Install the latest 3CXCRM.exe as the tapi driver was revamped.
    Your problems should be fixed.
    And consider updating from XP - the operating system is over a decade old.
  5. WEK
    WEK
    Mar 23, 2015
    I have the same problem on Win 8.1 x64 with 3CX V. 12.5 Tapi driver:
    When I dial a number from our external application, dialer.exe from microsoft starts with an error message: "There was an internal error. Close the program and start it again"
    If I then don't close dialer.exe and try again, and it works.
    If I close dialer.exe then dialog causes the same message again.
    Is there a solution for this problem ?
