3cx CTI with SNOM no line key usage possible V14Sp2
Discussion in 'Windows' started by proofficemhellmann, Jan 25, 2016.
  1. proofficemhellmann
    Jan 25, 2016
    one of our coustomer wants to use all function keys of his snom telefones and don't want to use the function keys as line keys.
    Now he installed the last updates V14SP2 there is the problem, that the software phone client every time dials first programming otions of key 1 and then the number you have dialed.
    Ok I can left the first key as a line key and then programming the rest keys but that's not what the coustomer wants.
    Is there a option or have I go back to V14SP1?
    Best regards for your help
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,375
    84
    I believe it is exactly the same in V14 SP1.
    You must leave at least the first line button there, I don't know of any way around that if you want CTI to work.
