3CX cuts call on SIP 302 moved temporarily message
Discussion in 'Android' started by Hans_V, Sep 17, 2012.
  1. Hans_V
    Sep 17, 2012
    I installed the 3cx client on a Samsung Android Phone (and on an iPhone) , when i Make a call to a set that is forwarded to another set, the gateway sends an SIP 302 moved temporarily message to the 3cx client, at that time the 3cx client seems to cut the call.
    so a sip feature does not work on the 3cx clietn (same behaviour on Android and on iPhone)
    Is this a known problem ?
    is there a solution (or upgrade) for this ?
    thanks in advance for your reply
    kind regards
    Hans
  2. Hans_V
    Sep 17, 2012
    version of the Android : 2.0.5
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    HANS_V - are the phones forwarded using the Phones Features or 3cx Status features (MyPhone) ?
  4. Hans_V
    Sep 17, 2012
    THe 3CX client is connected as a SIP client (user) on a Alcatel (PBX)SIP gateway, I tried to call a (normal) phone which is forwarded using the phone features on the Alcatel.
    kind regards
    Hans
