3CX database?
Discussion in '3CX Phone System - General' started by iperez_genius, Jul 24, 2008.
  1. iperez_genius
    Jul 1, 2008
    56
    Is it possible to access and view the 3cx database?
    if so how...
    where can i find the DB name, username and password?
    Ilan
  2. Anonymous
    Anonymous Guest
    http://docs.google.com/View?docid=dqnz5cc_59cb9jn8hp
  3. francesco
    francesco New Member
    Jun 23, 2008
    102
    you can use pgadmin III
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    5.1 Accessing the 3CX Database
    To access the database from another server than the localhost or the server where the software is installed on you have to make some changes to the PostgreSQL configuration.
    <3CX install dir>\Data\DB\pg_hba.conf
    In the # IPv4 local connections: section
    Type Database User CIDR-address Method
    Host All All 127.0.0.1/32 Password
    Host All All <your IP range like eg 192.168.0.0 >/24 password
    The IPv6 stuff is not supported by 3CX as yet so leave that for the time being.
    <3CX install dir>\Data\DB\ postgresql.conf:
    # - Connection Settings -
    listen_addresses = '*'
    # SDP allowed any IP address to be listened for!
    # was restricted to 'localhost'
    port = 5480
    max_connections = 250
    This can be troublesome.. after any changes stop and start the 3cx Database service and then check your postgresql log for any issues (located at: C:\Program Files\3CX PhoneSystem\Data\DB\pg_log)
    Now on your client PC:
    Download the psqlodbc Win 32 version from here:
    http://www.postgresql.org/ftp/odbc/versions/msi/ (get latest release - from the bottom!) and install it.
    Add an ODBC Connection (Start/Control Panel/Administrative Tools/Data Sources (ODBC), choose at Add under the System DSN TAB and choose the Psqlodbc driver, the details entered should be as follows:
  5. Henk
    Henk Member
    Nov 13, 2007
    250
    MS Access? ( walking away head shaking).
    But lets not start a discussion about that ....... :)/
  6. Henk
    Henk Member
    Nov 13, 2007
    250
    I know it works, just kidding with ya.
    Personally I do not like MSAccess to much as a DB but that is just a personal thing.
    H
  7. Thona
    Aug 10, 2007
    54
    The DB is not access....
    ....just the reporting utility, if i unerstood that right.
    A funny choice, but understandable.
  8. cyclone76
    Mar 3, 2017
    44
    Can i install and use phpmyadmin to see sql database ?
