3CX Demo Server Unresponsive
Discussion in '3CX Phone System - General' started by DanTron, Nov 17, 2017.
  1. DanTron
    Nov 17, 2017
    10
    My 3CX demo server has gone offline.
    It responds to ping but refuses any other connections.
    I have tried from several different public IP address thinking it may have been an IP ban...
    I'm stumped. How can I reboot this Cloud VM?
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,599
    209
    Hi DanTron,
    When you try and access the console do you get a 502 bad gateway or 403 Forbidden message or something like that ?
    The behavior you are getting I would agree does match what you would get if you logged into the console incorrectly 4 times. Can you log directly onto the server itself ? Is it Windows or Linux ?
  3. DanTron
    Nov 17, 2017
    10
    I'm getting a ERR_CONNECTION_REFUSED.
    not a 502 or 403.
    It's running on Debian I believe.
  4. eddv123
    Aug 15, 2017
    1,599
    209
    Hi DanTron,
    What are you typing in the address bar? https://yourFQDN:5001?
    If you try nslookup of your FQDN, does it resolve to the correct IP?
  5. DanTron
    Nov 17, 2017
    10
    #5 DanTron, Nov 17, 2017
  6. eddv123
    Aug 15, 2017
    1,599
    209
    I cannot access either, and yes your DNS resolves correctly. Have you created rules in your local firewall on the 3CX for HTTPS specifically from your location(s) ?
    Where are you hosting ? I use AWS and you need to apply filter rules.
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Did you use the PBX express trial account? Was this created a month ago? If so then the instance has been deleted as these installations are deleted after 29 days
  8. Milos
    Nov 17, 2017
    Hallo same happened to me today. I am not able to login my account https://xxxxx.3cx.at, still getting message
    WARNINGS.WEB_SERVER_NOT_RESPONDING. IP and dns records are correct and is able to ping them. I thought it was due to 3cx update that was done last night. I also have trial pbx express account made o October 18th. System was running nice and I was preparing to buy a license. So now did I loose everything? All settings? How to continue with moving to google instance?
  9. YiannisH_3CX
    May 10, 2016
    7,783
    561
    Hello @Milos
    When the trial period ends the instance is automatically deleted. If you did not have a backup then all configuration is lost. If you would like to host your PBX to google you will need to create your own google instance and install the PBX to that.
  10. Milos
    Nov 17, 2017
    Hello @YiannisH_3CX
    thank you very much for your reply. I did it already a set it up again on Google Cloud.
