3CX deployment consideration !
Discussion in '3CX Phone System - General' started by ovais.mb, Oct 7, 2008.
  1. ovais.mb
    Oct 7, 2008
    Hi all, i was considering deploying 3CX in our bank. we will be having almost 200 branches this year ( more to come in future). every branch has number of users = 30 ( average ). Currently we have 130 branches online.
    Now considering the flexibility of 3CX, and its limitation of simultaneous calls to 32 ( in some post i have read 128 ).
    Can i deploy 3CX in my environment if i have atleast 5 ip phones per branch that makes a total of 1000 phones in my domain. Any 1 should be allowed to talk to any 1 !!!
    Is it possible with 3CX ? ( i was asking this in the context of number of simultaneous calls, because they are too small !!! )
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    any way it's better to make a server at each branch
    to manage internal calls and external calls for local lan
    and the calls between branches can use 3CX bridge or a lot of other solutions with 3cx
    so 128 call will be enough as I think
  3. ovais.mb
    Oct 7, 2008
    Sorry but i am new to 3cx, if i need to deploy 4 servers lets say, do i have to purchase it just once or i have to buy seperate licenses ?
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Check
    http://www.3cx.com/ordering/pricing.html
    and you do not have to pay for 128 calls in all branches
  5. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Also, keep in mind your handset to handset calls are not going to be counting against your call capacity.
  6. mickp
    Jun 9, 2008
    72
    Just to clarify... Are you saying that internal calls do not count against the concurrent call limits?
    Mick.
  7. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    Hello & Welcome to the 3CX group :p
    You could group branches together that are in the same geo location. But 30
    users per branch & 130 branches is more that one 3CX can handle. If you
    have 1000 phones & everybody gets on the phone at the same time you will
    need 10 3CX systems to power everything. You would need a custom 3CX VM
    setup to handle all 130 branches & a custom dialing plan to reach each branch.
    ecwilson
  8. worksighted
    Aug 19, 2008
    204
    I take that back, after testing to check, ext to ext calls count as calls.
  9. mickp
    Jun 9, 2008
    72
    Damn (I think). You mention 'ext to ext calls' but do internal to internal calls count?
    Mick.
  10. BlindFaith
    Oct 9, 2008
    I believe he was specifying Extension to Extension calls, count, which are internal. As I understand it the concurrent call limit is all calls that the server has to process simultaneously, and those are processed by the server. External calls would be limited by Gateways or Voip Provider utilitization, up to the limit of the Server implementation.
  11. mickp
    Jun 9, 2008
    72
    Thanks Matt. I was just being hopeful. It's extremely unlikely that our 30 people will have more than 16 calls going anyway.
    Mick.
