3cx detect wrong incoming call
Discussion in '3CX Phone System - General' started by henlon, Jan 31, 2010.
  1. henlon
    Jan 3, 2007
    8
    I'm using 3cx 7.1.7139.0 on a 2003 server.
    I have one provider with two different numbers, 401000 and 401010
    When I receive an inbound call to 401010 it detects it on the 401000 port
    What about this missbehavior?
    Here comes two lines from the log:
    19:08:31.968 [CM503001]: Call(22): Incoming call from 015014498@(Ln.10002@Cellip00) to <sip:801@192.168.0.15:5060>
    The right port would be Cellip10 not Cellip00
    In the next line:
    19:36:40.186 [CM505003]: Provider:[Cellip00] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sippy] Transport: [sip:192.168.0.15:5060]
    Is there something in my setup I'll have to change?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,309
    If you're talking about UDP port than there's misunderstanding, because UDP ports range from 0 to 65535, so it can not be any 6 digit number
  3. henlon
    Jan 3, 2007
    8
    No I mean the ports to the provider.
  4. archie
    3CX Support
    Aug 18, 2006
    1,309
    Fix source identification rules than.
  5. henlon
    Jan 3, 2007
    8
    These two lines discover the problem taken from the call log:
    22:59:53.810 [CM505003]: Provider:[Cellip00] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Sippy] Transport: [sip:192.168.0.15:5060]
    22:59:53.810 [CM503001]: Call(67): Incoming call from 0706691767@(Ln.10002@Cellip00) to <sip:801@192.168.0.15:5060>
    The incoming call is for the port with Ln.10001 but all incoming calls goes to Ln.10002
    As you can se in the first raw: Device not Identified
    The both lines comes from the same Sip privider but with different numbers.
    Is there any settings I have to do?
