dear vinod700,
If I understand correctly, you want to have the ability to call the main number of a trunk followed by an extension number so you can connect automatically, is that correct?
A pause would have to be "created" in the set (speed call number) doing the dialling. In most cases, the first number, before the pause, is sent as a SIP message (and routing of the call done on that), whereas the digits after the pause are generally sent as DTMF (which may be converted to a SIP message along the line). Same way your mobile phone would do it.[/ QUOTE]
Hello
can you tell how will be the dial patterns which key / chartecter act as pause
dear vinod700,
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
