3cx dial plan context
Discussion in '3CX Phone System - General' started by solg, Dec 10, 2014.
  1. solg
    Dec 10, 2014
    Hello 3CX'ers,
    I am trying to find out if 3cx has a Dial Plan and if so where is it located. Here's what I am doing.
    I am configuring Odoo ERP for testing and there's an Asterisks module that requires some key information and one piece of that information is a Dialplan Context which I have no clue where to locate. Does anyone here under what it is referring to?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
    Asterick:
    X matches any digit from 0-9
    Z matches any digit from 1-9
    N matches any digit from 2-9
    [1237-9] matches any digit or letter in the brackets
    (in this example, 1,2,3,7,8,9)
    [a-z] matches any lower case letter (introduced in which Asterisk version?)
    [A-Z] matches any UPPER case letter (introduced in which Asterisk version?)
    . wildcard, matches one or more characters
    ! wildcard, matches zero or more characters immediately
    Context "local":
    Extension Description
    _9NXXXXXX Local calls
    Context "longdistance":
    _91NXXNXXXXXX Long distance calls
    include => "local"
    The context local has one extension pattern to permit dialing 7-digit numbers only (local calls)
    The context long distance has one extension pattern to permit dialing a long-distance call, and it also includes the context "local", thus permitting the user to make local calls.
    So my guess would be it is looking for the "Context" line... which 3cx does not have specifically.
