3CX - Disconnects Fax Immediately
Discussion in '3CX Phone System - General' started by deichb, Apr 3, 2012.
  1. deichb
    Apr 3, 2012
    I have been trying for weeks not to figure out why my fax number keeps disconnecting. I have been reassured by my provider it is running to a T.38 line. Whenever I attempt to send that fax, it rings and immediately disconnects the line. I have setup the Venta Fax software with Fax VOIP T38 software as well as the included 3CX Fax relay system. Either way, it is not working. Has anyone correctly setup this scenario to receive faxes (either through 3CX relay) or via Venta Fax? All help is appreciated.
    Thanks,
    Brad
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Why do you think that 3CX PhoneSystem disconnects the call?
    P.S. http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
  3. netswork
    netswork Active Member
    Mar 11, 2011
    577
    I have seen this issue when t.38 is not enabled on the voip provider. I am currently waiting on my provider to provision a line as t.38. As it stands right now when you call it and its routed to the fax virtual number the call is dead air then hangs up. This is on nexvortex, and I have seen this behavior in the past when the voip provider had not provisioned the line for t.38
  4. deichb
    Apr 3, 2012
    Here is what the 3CX log says...
    16:05:44.072 [CM503008]: Call(111): Call is terminated
    16:05:42.397 [CM503007]: Call(111): Device joined: sip:888@192.168.1.72:5100;user=phone
    16:05:42.395 [CM503007]: Call(111): Device joined: sip:8820696051@***.***.***.132:5060
    16:05:42.392 [CM503002]: Call(111): Alerting sip:888@192.168.1.72:5100;user=phone
    16:05:42.342 [CM503025]: Call(111): Calling @[Dev:sip:888@192.168.1.72:5100;user=phone]
    16:05:42.325 [CM503004]: Call(111): Route 1: @[Dev:sip:888@192.168.1.72:5100;user=phone]
    16:05:42.325 [CM503010]: Making route(s) to <sip:888@192.168.1.100:5060;user=fax>
    16:05:42.320 [CM505003]: Provider:[Phones] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [FPBX-2.9.0(1.8.7.0)] PBX contact: [sip:********51@***.***.***.114:5060]
    16:05:42.313 [CM503001]: Call(111): Incoming call from 1********55@(Ln.10005@Phones) to <sip:888@192.168.1.100:5060;user=fax>
    16:05:42.293 [CM503012]: Inbound any hours rule (unnamed) for 10005 forwards to Fax:888
    I hope this helps for added information.
    I am not sure if it is 3CX or if my settings are just off base. Could it be that my VOIP service provided ran my fax line through the same username & password setup as the other four lines? For instance, my inbound is as simple as adding a *5153 in the DID and then asking it to link to 3CX Fax (send email to ext 888).
    Thanks...
