3CX does not save configured office hours
Discussion in '3CX Phone System - General' started by adamwells, Oct 9, 2015.
  1. adamwells
    Mar 20, 2015
    25
    I'm trying to set up our Office Hours. I press save, and if I check back it appears to have saved. But after I go on another section and check again, it will have changed back to the default (7:30 - 5).
    Does anyone know why this would be happening? IS there a service that needs restarting after applying the change?
  2. 12494
    12494 Member
    Apr 16, 2010
    298
    30
    As I recall - you have to click save on the screen where you specify the hours - and then save on the screen that you land on after you click that first save.
    Allen
  3. adamwells
    Mar 20, 2015
    25
    Hit the nail on the head! Thanks!
