3cx doesn't detect T38 media
Discussion in '3CX Phone System - General' started by the.neon, Oct 21, 2012.
  1. the.neon
    Sep 22, 2012
    Hi ,
    I have the problem that the sending of a fax doesn't work.
    For me it looks that the 3cx doesn't detect the media switch to the T38 protocol.
    The Gateway switch to the T38 :
    m=image 31234 udptl t38
    a=T38FaxVersion:3
    a=T38MaxBitRate:33600
    But the 3cx send to the voip client :
    s=3cxPS Audio call
    c=IN IP4 192.168.110.225
    a audio signal .
    Where is the problem ? I have a V10 System on the newest patch .
    Best Regards
    Daniel
    Complete Log:
    NVITE sip:3cx@192.168.110.225:5066 SIP/2.0
    Via: SIP/2.0/UDP 192.168.110.250:9803;rport=9803;branch=z9hG4bK1100028672-330500756
    Max-Forwards: 70
    Contact: <sip:007552@192.168.110.250:9803>
    To: "92287" <sip:3cx@192.168.110.250:9803>;tag=6460cf3e
    From: <sip:007552@192.168.110.250:9803>;tag=sipcontrol_1095177672-330369684
    Call-ID: MGI2NDU5ZTExYzM3Yjc4NGQ5YTk0ZjcwODI1ZjM3OTA.
    CSeq: 2 INVITE
    Session-Expires: 600;refresher=uac
    Min-SE: 90
    Accept: application/sdp, application/simple-message-summary
    Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, NOTIFY, REFER, PRACK
    Content-Type: application/sdp
    Supported: 100rel, replaces, timer
    Content-Length: 402
    v=0
    o=SIPcontrol 165119306 165119311 IN IP4 192.168.110.250
    s=-
    c=IN IP4 192.168.110.250
    t=0 0
    m=audio 0 RTP/AVP 0 101
    a=T38FaxVersion:3
    a=T38FaxFillBitRemoval:0
    a=T38FaxTranscodingMMR:0
    a=T38FaxTranscodingJBIG:0
    a=T38FaxRateManagement:transferredTCF
    a=T38FaxMaxDatagram:128
    a=T38FaxMaxBuffer:284
    a=T38FaxUdpEC:t38UDPRedundancy
    a=sendrecv
    20:53:43.843|.\TransactionUser.cxx(74)|Debug8|Resip|::ResipLogger:Match!
    20:53:43.843|.\Helper.cxx(375)|Debug8|Resip|::ResipLogger:Helper::makeResponse(SipReq: INVITE 3cx@192.168.110.225:5066 tid=1100028672-330500756 cseq=INVITE contact=007552@192.168.110.250:9803 / 2 from(wire) code=100 reason=
    20:53:43.843|.\TimerQueue.cxx(85)|Debug8|Resip|::ResipLogger:Adding timer: Timer Trying tid=1100028672-330500756 ms=80
    20:53:43.843|.\TransactionState.cxx(2112)|Debug8|Resip|::ResipLogger:Send to TU: TU: DialogUsageManager size=0
    INVITE sip:3cx@192.168.110.225:5066 SIP/2.0
    Max-Forwards: 70
    CSeq: 2 INVITE
    Min-SE: 90
    Content-Length: 402
    v=0
    s=-
    t=0 0
    a=T38FaxVersion:3
    a=sendrecv
    20:53:43.843|.\Authorization.cpp(857)|Debug2||FindBlacklistEntry:EBL: IPBL found ip = 192.168.110.250; result = not found
    20:53:43.843|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: MGI2NDU5ZTExYzM3Yjc4NGQ5YTk0ZjcwODI1ZjM3OTA.-6460cf3e-sipcontrol_1095177672-330369684
    20:53:43.843|.\DialogUsageManager.cxx(1333)|Trace5|Resip|::ResipLogger:Got: SipReq: INVITE 3cx@192.168.110.225:5066 tid=1100028672-330500756 cseq=INVITE contact=007552@192.168.110.250:9803 / 2 from(wire)
    20:53:43.843|.\DialogUsageManager.cxx(1651)|Debug8|Resip|::ResipLogger:DialogUsageManager::processRequest: SipReq: INVITE 3cx@192.168.110.225:5066 tid=1100028672-330500756 cseq=INVITE contact=007552@192.168.110.250:9803 / 2 from(wire)
    20:53:43.843|.\DialogUsageManager.cxx(1711)|Trace5|Resip|::ResipLogger:Handling in-dialog request: SipReq: INVITE 3cx@192.168.110.225:5066 tid=1100028672-330500756 cseq=INVITE contact=007552@192.168.110.250:9803 / 2 from(wire)
    20:53:43.843|.\DialogSet.cxx(484)|Debug8|Resip|::ResipLogger:Found matching dialog mClientSubscriptions(0), mServerSubscriptions(0) for
    Max-Forwards: 70
    To: "92287"<sip:3cx@192.168.110.250:9803>;tag=6460cf3e
    CSeq: 2 INVITE
    Min-SE: 90
    Content-Length: 402
    v=0
    s=-
    t=0 0
    a=T38FaxVersion:3
    a=sendrecv
    20:53:43.843|.\Dialog.cxx(370)|Debug8|Resip|::ResipLogger:Dialog::dispatch: SipReq: INVITE 3cx@192.168.110.225:5066 tid=1100028672-330500756 cseq=INVITE contact=007552@192.168.110.250:9803 / 2 from(wire)
    20:53:43.843|.\SipMessage.cxx(986)|Debug8|Resip|::ResipLogger:SipMessage::getContents: application/sdp
    20:53:43.843|.\Helper.cxx(2131)|Debug8|Resip|::ResipLogger:Got sdp
    20:53:43.843|.\InviteSession.cxx(2561)|Trace5|Resip|::ResipLogger:Transition InviteSession::Connected -> InviteSession::ReceivedReinvite
    20:53:43.843|.\InviteADS.cpp(306)|Trace5||InviteADS::eek:nOffer:Offer from <sip:007552@192.168.110.250:9803>;tag=sipcontrol_1095177672-330369684 to "92287"<sip:3cx@192.168.110.250:9803>;tag=6460cf3e
    20:53:43.843|.\CallLeg.cpp(410)|Trace5||CallLeg::eek:nOfferArrived:OfferSDP arrived for session 125 of Leg C:2.2
    20:53:43.843|.\CallLeg.cpp(1126)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:2.2
    20:53:43.843|.\CallLeg.cpp(382)|Trace5||CallLeg::gotSdp:Leg C:2.2 raised event RecvdRemoteSdp
    20:53:43.843|.\Call.cpp(847)|Trace5||Call::Renegotiate:Reneg. from C:2.2, offer
    20:53:43.843|.\Call.cpp(963)|Trace5||Call::Renegotiate:providing SDP for C:2.1
    20:53:43.843|.\MSInterface.cpp(688)|Trace5||??:MSLogReports
    20:53:43.843|.\SLServer.cpp(832)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210002] C:2.1:Offer provided. Connection(transcoding mode): 192.168.110.225:7004(7005)
    20:53:43.843|.\ServerInviteSession.cxx(223)|Trace5|Resip|::ResipLogger:InviteSession::Connected: provideOffer
    20:53:43.843|.\InviteSession.cxx(2561)|Trace5|Resip|::ResipLogger:Transition InviteSession::Connected -> InviteSession::SentReinvite
    20:53:43.843|.\Dialog.cxx(1004)|Debug8|Resip|::ResipLogger:Dialog::makeRequest:
    INVITE sip:750@192.168.110.250:5066 SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-9e44f46fe2761b0b-1---d8754z-;rport
    Max-Forwards: 70
    Contact: <sip:007552@192.168.110.225:5066>
    To: <sip:750@192.168.110.225>;tag=fe1448c11
    Call-ID: fe1448c119b56766
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Supported: replaces
    Content-Length: 0
    20:53:43.843|.\InviteSession.cxx(2220)|Trace5|Resip|::ResipLogger:InviteSession::SentReinvite: startStaleReInviteTimer
    20:53:43.843|.\TimerQueue.cxx(105)|Debug8|Resip|::ResipLogger:Adding application timer: DumTimeout::StaleReInvite INVITE: 122 InviteSession::SentReinvite ADDR=<sip:007552@192.168.110.225>;tag=905a1c15 PEER=<sip:750@192.168.110.225>;tag=fe1448c11: duration=40 seq=2
    20:53:43.843|.\InviteSession.cxx(384)|Trace5|Resip|::ResipLogger:Sending SipReq: INVITE 750@192.168.110.250:5066 tid=9e44f46fe2761b0b cseq=INVITE contact=007552@192.168.110.225:5066 / 2 from(tu)
    20:53:43.843|.\InviteADS.cpp(272)|Trace5||InviteADS::eek:nReadyToSend:SendMsg from <sip:007552@192.168.110.225>;tag=905a1c15 to <sip:750@192.168.110.225>;tag=fe1448c11
    20:53:43.843|.\CallLeg.cpp(755)|Debug2||CallLeg::eek:nReadyToSend:Sending: SipReq: INVITE 750@192.168.110.250:5066 tid=9e44f46fe2761b0b cseq=INVITE contact=007552@192.168.110.225:5066 / 2 from(tu)
    20:53:43.843|.\Extension.cpp(1416)|Debug2||Extension::notifyDI:Ext.750: sip:750@192.168.110.250:5066, Call(2)
    20:53:43.843|.\Extension.cpp(1433)|Debug2||Extension::notifyDI:Call(2): DlgID:2-1938, entry state: 2
    20:53:43.859|.\DialogUsageManager.cxx(866)|Debug8|Resip|::ResipLogger:SEND:
    Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-ab22c40fc703c23a-1---d8754z-;rport
    Max-Forwards: 70
    CSeq: 2 INVITE
    Supported: replaces
    User-Agent: 3CXPhoneSystem 10.0.19079.0
    Content-Length: 303
    v=0
    o=3cxPS 500648902656 239008219138 IN IP4 192.168.110.225
    s=3cxPS Audio call
    t=0 0
    m=audio 7004 RTP/AVP 0 3 8 101
    a=rtpmap:0 PCMU/8000
    a=rtpmap:3 GSM/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-16
    a=sendrecv
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Please define your scenario. It looks like you are trying to send from one extension and receive at another.
    3CX itself is not setup to send faxes. The fax server is only set to receive. To send, you will need an appropriate ATA connected to a fax machines and both the ATA and your SIP provider must support T38. The fax will need to be configured as an extension. I am not aware of anyone having any real success with this, although there have been a few sporadic posts. From what I have seen, it seems like those who have had success seemingly were able to do so using pass thru mode using a G711 codec.
    Hopefully others who have had some success in this area will provide more guidance, but my own experience in trying as well as the lack of those who have tried indicate that it not easy and when successful, not always reliable.
  3. the.neon
    Sep 22, 2012
    Hi ,
    my scenario is
    SIP FaxSoftware ( DAVID) -> 3cx Fax Extension -> BRI GW
    so the FaxSoftware will send through the 3cx a fax to external number .
    The Problem I think is that the 3cx to FaxSoftware that the connection is a voice one and not T38 one.
    So how can I force the 3cx to switch to an T38 connection ?
    Regards
  4. lneblett
    Sep 7, 2010
    2,083
    61
    As I indicated, 3CX does not in and of itself support the sending of faxes. The software you have will need to integrate with 3CX and provide the signaling and then your gateway must also support t38. Not knowing the specifics of either the software or gateway make it problematic to even guess what needs to be done.
    However, go to the blog and enter in Relay Fax into the search. This is a software approach that reportedly is supported and does have t38 compatibilty. There might be enough information to glean from these posts that will steer you to a set-up solution for your scenario.
  5. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    It could be that it would be better if the fax software sent UDP packets straight to the BRI interface. Make sure that for both the FAX extension and the BRI gateway that PBX. Do this as follows:-
    Go the the gateway and on the advanced tab uncheck PBX delivers audio. Check both "Support re-invite" and "supports replaces". This assumes that the gateway does support both. On the extension, do the same by going to the "other" tab and do the same. Let us know whether this works, as I am interested. I have used fax successfully using T.38 for inbound and outbound. Also, try reducing the speed to 14,400.
    Richard
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Configure 750 as a fax extension. It should resolve "3cx doesn't detect T38 media" problem for v10.
    Transparent media delivery for video and t38 is available in v11.
  7. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Sy how would you configure that extension as fax extension? would simply changing the extension number in system extension status---> edit extension settings than chaning the extension from 888 to in this case 750 would resolve the isssue of "3cx doesn't detect T38 media" ? But in V11 this isnt necessary as at all? Thanks in advance
  8. rbc94
    Apr 24, 2012
    40
    in the management console, go to fax machines and click add fax extension.
