3cx Droid Help..
Discussion in '3CX Phone System - General' started by thereverend, Jun 17, 2011.
  1. thereverend
    thereverend New Member
    May 29, 2011
    100
    Can someone please give me step by step directions to set up my droid 3cx and the server side..
    thanks..
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    hello,
    http://www.3cx.com/blog/3cxphone/android/configuring/
    Good luck. Search the blog for additional information http://www.3cx.com/blog
  3. thereverend
    May 29, 2011
    100
    I have followed these instructions and still not registering..
    what could be wrong?
    User ID is set to the extension number
    ID is set the the Extension number
    pw the password i set up in 3cx for the extension
    Use Internal server is UN CHECKED
    Internal server is the 192.168 address of the server the INTERNAL IP
    the expternal is the PUBLIC IP that i can get to the server from outside the network
    Server port 5060
    Stun is set @ stun3.3cx.com
    proxi is the external IP
    Local port 5060
    timeout 120
    keep alive 60
    use TCP unchecked
    Enable NAT uncheked
    Enable ICE unchecked
    let me know if this is right or wrong..
    thanks
