3CX Drops second call
Discussion in '3CX Phone System - General' started by DJToMeK, Aug 18, 2015.
  1. DJToMeK
    Aug 18, 2015
    Hi! I am using 3CX Managment Console 12 and I have implemented PBX protocol in my android app. When I test this on my side everything works perfectly. When I installed this on another location, settings are basically the same, just different extensions but I get dropped call. So when I make a call from device 1 to device 2, device 2 picks up a call and a call is established. After the call device 2 hangs up on the call. Then the device 1 calls device 2 again, same as previously, the device 2 gets the call, accepts it on device 1 nothing happens, like the call is still ringing, on device 2 it gets shown like the call was accepted, but after 5 seconds both calls get ended. I checked 3CX logs and it just shows that the call was terminated and on my app I see that it sended back BUSY.
    Does anyone have any clue on why this would happen?
    3CX Logs
    http://txs.io/DAEb
