3cx ending the call instead of transfer
Discussion in '3CX Phone System - General' started by amartini, Jul 2, 2008.
  1. amartini
    Dec 28, 2007
    17
    I've installed today the new version 6 (before I used the 5.1). I have a problem: When someone call my number I redirect the call to a RING GROUP. After 25 seconds, If no one of the ring group has picked up the call, I redirect the call to the Digital Receptionist (Destination if no answer). With the 6 version of 3cx the call terminate instead of transfer to DR. I tried to redirect the call to another extension, but the call terminate.
    Please Help
    Andrea
  2. alberto.net
    Jun 10, 2008
    I've the same problem... with the transfer after ring group, or after the ivr... 3cx version 6.0612 / patton version 5.1
    Alberto
  3. raldridge
    Jun 6, 2008
    21
    I'm also seeing this issue.
  4. amartini
    Dec 28, 2007
    17
    I captured a Log:
    101 is the ringing group. 299, 180, 185 are extensions.
    Time Function Message
    15:25:20.900 Call::Terminate [CM503008]: Call(129): Call is terminated
    15:25:20.779 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:101
    15:25:20.639 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:101
    15:25:20.629 Call::RouteFailed [CM503015]: Call(129): Attempt to reach [sip:101@3cx.mediaplanet.local:5060] failed. Reason: No Answer
    15:25:05.177 Extension::printEndpointInfo [CM505001]: Ext.299: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX VoIP Client;Rev: 1] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Phone v5.1] Transport: [sip:192.168.0.243:5060]
    15:25:05.177 CallCtrl::eek:nAnsweredCall [CM503002]: Call(129): Alerting sip:299@127.0.0.1:5070;rinstance=03220560b717135f
    15:25:04.596 MediaServerReporting::SetRemoteParty [MS210002] C:129.4:Offer provided. Connection(transcoding mode): 192.168.0.243:7114(7115)
    15:25:04.456 MediaServerReporting::SetRemoteParty [MS210002] C:129.3:Offer provided. Connection(transcoding mode): 192.168.0.243:7112(7113)
    15:25:04.376 MediaServerReporting::SetRemoteParty [MS210002] C:129.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7110(7111)
    15:25:04.156 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(129): Calling: RingAll101:299Ext.299180Ext.180185Ext.185280285Ext.285@[Dev:sip:299@127.0.0.1:5070;rinstance=03220560b717135f, Dev:sip:180@192.168.0.251:5061, Dev:sip:185@192.168.0.252:5060]
    15:25:04.105 MediaServerReporting::SetRemoteParty [MS210000] C:129.1:Offer received. RTP connection: 192.138.136.228:10022(10023)
    15:25:04.105 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:101@3cx.mediaplanet.local:5060]
    15:25:04.045 CallLeg::setRemoteSdp Remote SDP is set for legC:129.1
    15:25:04.045 Line::printEndpointInfo [CM505003]: Provider:[ip_04441550077] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.0.243:5060]
    15:25:04.045 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:101
    15:25:03.925 CallCtrl::eek:nIncomingCall [CM503001]: Call(129): Incoming call from 380555xxxx@(Ln.10002@ip_04441550077) to [sip:101@3cx.mediaplanet.local:5060]
    15:25:03.515 LineCfg::getInboundTarget [CM503012]: Inbound office hours' rule for LN:10002 forwards to DN:101
    15:25:03.424 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:04441550077@192.138.138.190:5060;rinstance=4c26b46e20055a6f SIP/2.0
    Via: SIP/2.0/UDP 192.138.136.227;branch=z9hG4bK997e.519f2fc3.0
    Via: SIP/2.0/UDP 192.138.136.226:5062;branch=z9hG4bK-d87543-c2c5665d3c59353f-1--d87543-;rport=5062
    Max-Forwards: 16
    Record-Route: [sip:192.138.136.227;ftag=67dc0601;lr=on]
    Contact: [sip:cccgateway@192.138.136.226:5060]
    To: "04441550077"[sip:04441550077@sip.mediaplanet.it]
    From: "380555xxxx"[sip:380555xxxx@192.138.136.227:5060];tag=67dc0601
    Call-ID: 837bc1249943cb0c@YzA.
    CSeq: 1 INVITE
    Session-Expires: 100
    Min-SE: 90
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE
    Supported: timer
    Content-Length: 0
  5. kustura
    Nov 2, 2007
    53
    I am having the same problem, on top of it it does the same thing if you try to dial extension directly from DR menu. It rings to the extension and then it says "Call Transfer Failed" and goes back to DR.
  6. justin
    Feb 20, 2008
    79
    That there looks like after ring group 101 doesn't answer it is forwarding back to 101 again instead of DR. Are you sure it's setup ok? I don't think I have problems with mine (V6 - 612)
  7. Henk
    Henk Member
    Nov 13, 2007
    250
    Is your destination phone working? it seems that it tries for 15 seconds and than terminates.
    try this.
    Set the destination up to have all calls routed to the voice mail of that extension, see if you can leave a message, if so than the negotiation between your phone and 3CX is not configured correctly.
    H.
