3CX extensions do not hear voice of incoming calls
Discussion in '3CX Phone System - General' started by fabianus, Nov 6, 2007.
  1. fabianus
    Nov 6, 2007
    15
    Hello !
    When calls come in the caller hears the voice of the 3CX user but the 3XC user does not hear the caller's voice.
    I tried to disable the firewall, but this does not solve the problem.
    Thank you very much for any hint !
    Regards,
    Fabianus
  2. fabianus
    Nov 6, 2007
    15
    got it :)
    it was about the ports of the router ;-)
    Regards,
    Fabianus
