3cx Fax no longer working in SP5
Discussion in '3CX Phone System - General' started by craigreilly, May 7, 2014.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    We updated to SP5 yesterday and now we can not receive faxes via 3cx.
    When I change the destination from a 3cx fax (8888) to a physical fax machine via "3cx Fax Extension" to GrandStream 704 it works fine.
  2. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Upgraded to SP5 the day after it came out. Fax working fine here. sorry, I know that's no help. :(
  3. craigreilly
    Feb 1, 2012
    3,587
    309
    Interesting - any chance you want to tell me your provider or codecs in use or other settings - reinvites, replaces, etc...
  4. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Hi Craig.
    My Voip Provider is Nexvortex and the assigned Codecs are
    G-711 U-law
    G-711 A-law
    GSM-FR
    supports Re-Invite: UN checked
    supports replace: UN checked
      File size:
      124.8 KB
      622
  5. craigreilly
    Feb 1, 2012
    3,587
    309
    Thanks George... I am having random luck with some fax services and not others.
