3CX Fax server hangs
Discussion in '3CX Phone System - General' started by matthijsolislagers, Jan 25, 2008.
  1. matthijsolislagers
    matthijsolislagers New Member
    140
    Everytime I try to stop the 3CX Fax service it keeps in 'Stopping' state. Killing to process does the trick.
    When upgrading 3CX the installation also tries to stop the service cousing the upgrade to fail.
    Anyone had the same problem?
  2. Alexander
    Nov 10, 2006
    73
    Hi !
    Please send log-files to me (alexander@3cx.com)
    Alexander
  3. matthijsolislagers
    140
    Hi Alexander,
    What log files do you want? The server log doesn't show anything..
