- Joined
- Apr 2, 2009
- Messages
- 1
- Reaction score
- 0
I've got problems installing the 3cx fax server on windows 2008 sbs server 64 bit.
I've installed the fax server role first on the server, no problems.
Then I want to try to install the 3cx fax server, clicking next, accepting default install folder.
And then i'm supposed to fill in the 3cx phone system ip, on default it's filled in with 127.0.0.1 and that's correct, because the 3cx system is on the same server as where i want to install the fax server. After clicking on next i got the following error:
"Error: The connection to the host has failed"
Filling the ip adress or hostname of the server gives the same error.
i'm ussing 3cx 7.0
i'm ussing 3cx 7.0
