3CX FAX Server
Discussion in '3CX Phone System - General' started by alenz, Apr 13, 2011.
  1. alenz
    Mar 25, 2011
    13
    Hi Everyone,
    I just reinstalled our 3CX Server due to a hardware failure; and now don't see the 3CX Fax Server in the links.
    Any suggestions?
    Thanks!
  2. alenz
    Mar 25, 2011
    13
    Anyone have the link for it or any suggestions please?
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Did you license your 3CX after the reinstall? Fax is not available in the free version so check your status. Unless I am not understanding exactly what your asking.
  4. alenz
    Mar 25, 2011
    13
    Hi Nate,
    I did re license the server after re-installing, and it shows that the license is activated.
    I'm guessing something somewhere didn't register properly?
    Thanks!
  5. nbailey
    nbailey Member
    Jan 31, 2011
    359
    So I take it that worked for you, excellent. I have seen it happen before. But glad your back up and running.
