3CX Fax Server
Discussion in '3CX Phone System - General' started by Goodheart, Dec 14, 2015.
  1. Goodheart
    Dec 14, 2015
    Hi, what is the meaning of this error:
    Code:
    01:32:57.857|3272|(0):FAXServer,
    (nai 0, conn_id  39) SSC Evt: Receive SSC_INVITE_IN
    01:32:57.899|3272|(0):FAXServer,
    (nai 0, conn_id  39) SSC Evt: Send SSC_SET_PARAM_SESSION_RQ
    (nai 0, conn_id  39) SSC Evt: Send SSC_INVITE_RS (100 Trying)
    01:32:57.900|3272|(0):FAXServer,
    (nai 0, conn_id  39) SSC Evt: Prepare SSC_INVITE_RS (200 OK)
                                Remote Media IP address   = [127.0.0.1] (7190)
                                Media Audio
                                Local <user phone number> = 888
                                Session activated (NAI)   = 1
                                Local Media IP address    = [127.0.0.1] (10000)
    (nai 0, conn_id  39) SSC Evt: Send SSC_INVITE_RS (ret_code: 200 (OK))
    01:32:57.987|3272|(0):FAXServer,
    (nai 0, conn_id  39) SSC Evt: Receive SSC_ACK_IN
    01:32:59.398|3272|(0):FAXServer,
    (nai 0, conn_id  39) SSC Evt: Send SSC_INVITE_RQ (re-invite)
                                Media T.38 (UDP (UDPTL))
                                    T38FaxVersion         : 0
                                    T38MaxBitRate         : 14400
                                    T38FaxRateManagement  : transferredTCF
                                    T38FaxFillBitRemoval  : OFF
    01:32:59.399|3272|(0):FAXServer,
                                    T38FaxTranscodingMMR  : OFF
                                    T38FaxTranscodingJBIG : OFF
                                    T38FaxMaxBuffer       : 10500
                                    T38FaxMaxDatagram     : 1500
                                    T38FaxUdpEC           : t38UDPRedundancy
    01:32:59.543|3272|(0):FAXServer,
    (nai 0, conn_id  39) SSC Evt: Receive SSC_INVITE_CO (Ret code: (488) SIP_RET_NOT_ACCEPTABLE_HERE (488 Not Acceptable Here))
    01:32:59.544|3272|(0):FAXServer,
                                Call rejected
    (nai 0, conn_id  39) SSC Evt: Send SSC_CLOSE_SESSION_RQ
    (nai 0, conn_id  39) SSC Evt: Receive SSC_CLOSE_SESSION_CO
    (nai 0, conn_id  39) SSC Evt: Receive SSC_CALL_CLOSED_IN
    (nai   1)            Session [User info: nai 1  Session cnt 0  Batch cnt 0] idle
    Trying to get 3cx fax server to receive via voip provider. Currently only works for faxes from our Patton gateway.
    Forced G711U, but the 3cx fax server hangs up after 1 second, even when i try test calling from an extension. Is there a way to disable FOIP?
    Any other solutions for fax-to-email from voip provider?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    The fax server is wanting to use t38 as the protocol which is the generally accepted more robust method for FoIP. Your provider should be t38 capable in order to use effectively. g711 is an audio codec which is not as tolerant of the latency and other issues associated to internet carriage when faxing. The Patton can get away with it as when sending to 3CX there is only the local network to contend with and it also accommodates t38 as well as g711. If sending to the 3CX fax server extension, it likely converts to t38. Using g711 can be very challenging and is more prone to failure the longer the fax.
  3. Goodheart
    Dec 14, 2015
    Hi Ineblett,
    Thanks for the response, i am aware that G711U isn't the best for faxing. I however dedicated a solid fiber internet connection to VOIP exclusively and want to give it a try. Do you know of anyways to get the 3CX fax server to play ball?
    Is it possible? if not, are there any other SIP Fax clients that could convert to PDF? My client is spoiled on the fax to PDF functionality now and doesnt want to go back to wasting paper.
    Thanks so much!
  4. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    I only know that
    The 3CX Fax Receiving Server does not support G.711 for fax.
  5. Goodheart
    Dec 14, 2015
    ok... im now investigating if its possible to connect the patton 4960 to the sip account, so that faxes will flow through it and then to the 3cx fax server
  6. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    You might be better asking your provider if they can do fax to email at network level. This also then has the benefit of not using your 3CX Channel licence and can be left dealing only with voice.
