3cx Fax server
Discussion in '3CX Documentation' started by novaks, Sep 28, 2017.
  1. novaks
    Dec 2, 2015
    i have a question about Fax server with g711 support. How many lines could be at the same time used for incomming faxes? Is it possible to receive more faxes at the same DID and at the same time? Is there any configuration file where to see/set this?
