3CX Fax To Email
Discussion in '3CX Phone System - General' started by nictwo2269, Sep 22, 2012.
  1. nictwo2269
    Jan 18, 2012
    8
    We just installed a new customer. It is a law office and they had 13 Fax to email addresses from CBeyond and are requesting 9 more numbers. I knew that you could create additional fax extensions in the 3cx however I have now learned you cannot add new email addresses to those created extensions.
    So my question is there any way that we can do fax to email with 3cx to 22 different DID's and 22 different email addresses?
    This is critical to this current deal and any help would be appreciated.
  2. nictwo2269
    Jan 18, 2012
    8
    I guess I am just slow on this Saturday. Problem resolved.
