3CX Fax using PRI
stash
Anyone tried 3CX Fax using Patton Smartnode 4970 and using Grandstream Handytone 286 to receive and send Fax using Traditional Fax Machine.
I just want to know if there are issues.
Thanks,
STASH
Incoming faxes on the Patton 4970 with a PRI work well.
We are attempting to use a Linksys SPA devices for outgoing, still messing with it tho.
Hi Dm,
OK thanks for the feed back try using Grandstream FXS gateway. I already work this out using Grandstream FXO and FXS.
So now i'm just trying this out using PRI.
Thanks,
STASH
Just an update, the linksys SPA-3102 works well, able to send and receive faxes to other fax machines and the 3cx fax server. We are only using it for outgoing, but we did get it to work for incoming as well.
Hi Dm,
Thanks will try that if will be needed.
Thanks,
STASH
Get 3CX - Absolutely Free!
3CX
