3CX Firewall Checked Returning Failed
Discussion in '3CX Phone System - General' started by nathanmsaunders, Aug 21, 2016.
  1. nathanmsaunders
    Aug 21, 2016
    32
    Hi Guys,
    i have and issue where the 3cx firewall is returning the below error
    Internal port number (XXXX) does not match external port number (XXXX)
    is there a way to fix this, this is a clean install of 3CX single instance V14
    10,767
    286
    What type (make/model) router are you using? Are all of the port forwarding setting correct? Could it be doing port substitution? Were you using a previous version of 3CX (with no changes to the router) with no errors? Is there any other firewall involved?
  3. nathanmsaunders
    Aug 21, 2016
    32
    thanks for taking the time to reply
    there is a tplink firewall however all the port forwarding is forwarded i have also dmz and factory reset the router. i have also DMZ the router.
    i have tested it without any network cable and it still products the same issue it sends out one port then comes back another
