3CX for a 50 user company spread across 4 locations
Discussion in '3CX Phone System - General' started by Stu, Aug 27, 2008.
  1. Stu
    Stu
    Aug 27, 2008
    Hi All,
    I'm thinking of deploying 3CX for a 50 user company spread across 4 locations with the 3CX server in a data centre and the office connected by MPLS network.
    Is this a suitable configuration or do I need a bigger product such as CISCO call manager etc? I would have liked a 3CX in each branch but from what I read the 3CX supports only 2 server linked, is this correct?
    Any help and advice would be much appreciated.
    Thanks,
    Stuart
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Stuart,
    Welcome to 3CX
    3CX System unlimted users and lines to register
    but the limit in license is up to 128 simultaneous calls
    any numbers of servers can connect to the main server
    and any plan you need is very easy to do with 3CX System
  3. Stu
    Stu
    Aug 27, 2008
    Both,
    Thanks for you quick replies, the business in question is a solicitors (lawyers) practice in the UK with 4 offices the main office has around 20 users/extensions and the 3 other offices have around 10 users/extensions.
    the main office will need capacity for 6 simultaneous external calls and the other 3 offices capacity for 4 simultaneous external calls. Internal calls between sites around about the same.
    I want full presence information and will probably install the soft phone on all PC's in desk phone mode with a mixture of Snorm 300, 360 and 370 handsets.
    All sites have ADSL 2mb/512 MPLS links which I don't think will support the additional VOIP traffic so I'm think of installing dedicated ADSL lines for the VOIP traffic.
    So now knowing that I can link multiple 3CX servers I'm thinking a 3CX in each site linked to a central site 3CX in the data centre witch will carry the SIP Trunk connection, this will allow the company to redeploy 3 receptionists and use one receptionist or IVR to route calls for all sites.
    The idea is that 3 x receptionists at £17k per year can be redeployed thus saving £51k per year and paying for the VOIP install, so theirs a fare bit of money to play with, if the above solution can be improved upon on the flip side I don't want to waste money.
    What do you guys think?
    Stuart
  4. Stu
    Stu
    Aug 27, 2008
    Ideally yes presence for all offices, is that not possible?
  5. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Please send more details about your plan
  6. Stu
    Stu
    Aug 27, 2008
    What addtional details do you require?
  7. amygoda
    amygoda Member
    Sep 18, 2006
    436
    The details you’re worry not to find
  8. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Grandstream blf works with vpn
