3CX for Home
Discussion in '3CX Phone System - General' started by jrahma, Aug 25, 2011.
  1. jrahma
    Aug 25, 2011
    Our house is 3 floors where my brothers lives. I want to connect the main number to the 3CX PBX and give everyone an extension..
    1. Is this possible at home?
    2. Do I need a license for this?
    Thanks,
    Jassim
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    sure, no need for a lic if you just want to do that.
  3. jrahma
    Aug 25, 2011
    If my main home number is 17222222 is there anyway to hae direct numbers for every extension, for example fr extension number 111 it will be 17222111 and for ext 835 it will be 17222835.... etc?
  4. willow
    willow Member
    Mar 1, 2011
    471
    it would be best to have the main number answered by a digital receptionist and then the user can dial an extension number. you could also purchase from a carrier a number for each extension. but the DR would be the cheapest way to go.
