3cx for Windows - through Proxy
Discussion in 'Windows' started by voglsafe, Feb 16, 2016.
  1. voglsafe
    Sep 25, 2014
    9
    Hy,
    I've try to use the 3cxPhone for Windows Client. I've already sent a welcome notification from the 3cx System and was able to configure my client. But the 3cx Phone Client can only connect if the proxy is disabled.
    I use a http proxy which requires a user/pass authentication. when I trace the traffic with wireshark I could see that the client try to connect through the proxy but coulnd't because the authentication failed.
    How can I use the 3cx Phone Client for Windows with a proxy server?
    thank you
    Felix
    10,744
    281
    Just to be clear, in my mind...The 3CX phone is being used at a remote location that has a proxy server, correct?
    Have you tried manually modifying the Proxy settings, in the phone? "Use outbound Proxy server"
    http://www.3cx.com/voip/ip-phone-help/voip-provider/
