3CX for Windows v14 cannot login
Discussion in 'Windows' started by PepePineda, Oct 30, 2015.
  1. PepePineda
    Oct 30, 2015
    13
    Hello, i am running some test on 3cx 14, i have installes 3cx for windows on my Windows 10 with Symantec Security protected PC, bur the soft phone did not login, i have tried this by installing the Android on my cell phone and it logs in OK.
    Do you have some tips about this Windows configuration??
    PS: I can ping the 3CX PBX with no problem from my computer and the extension is properly set
  2. Chris_3CX
    3CX Support
    Nov 4, 2015
    8
    If this issue has yet to be resolved:
    Have you checked the "PhoneSystem Event Log" from the 3CX Server manager when you attempt to Register the Soft Phone?
    Is Your Windows 10 installation fully up-to-date?
    Have you tried to disable your antivirus/Firewall?
    Have you tested any other phones such as a Hard phone, Soft phone from another pc?
