Solved 3cx for windows will not run
Discussion in 'Windows' started by steve matten, Jan 19, 2017.
  1. steve matten
    Dec 19, 2016
    17
    I have a problem running 3cx on some of my windows 7 workstations and not on others. The one that is bugging me the most is an i3 3.07 GHz with 4.00 GB of memory. This is a 64 bit machine.
    Right now I have 12.5 installed, it won't run. The system manager says the program starts but then it just quits.
    History:
    - Clean install of 12.5 for test. It worked.
    - Upgrade to 15 and the system hung up at the C++ 2015 Redistribute at the end when it is trying the install the .msu
    - from there tried to remedy the .msu problem
    - gave up and did a system restore to previous version and tried re-installing 12.5, now that won't run.
    Why does the program start (12.5 or 15) and never complete? There is plenty of memory and the software runs on lesser systems.
    Thanks for your help.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,514
    361
    Hello @steve matten
    your machine resources are plenty for the PBX to install so i do not think the issue is there. Make sure that your windows installation is not corrupted in any way or that version 12.5 was completely un-installed. Ensure all windows updates are installed especially the .net ones.
    For v15 you will need Visual C++ 2015 Redistributable (x86) and (x64)
  3. steve matten
    Dec 19, 2016
    17
    Thank you, I am now able to install on the machines that were a problem. I removed any previous versions of Visual C++ Redistributable, and 3CX 12.5, rebooted and restarted from scratch.
  4. YiannisH_3CX
    May 10, 2016
    5,514
    361
    Glad to hear the issue is resolved
