3cx FQDN
Discussion in '3CX Phone System - General' started by contraserv, Aug 10, 2016.
  1. contraserv
    May 12, 2015
    Since the release of v15, there is a 3cx FQDN for non static IP addresses. Are there any issues with this service? As of today it is not updating to the current public IP?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,552
    298
    They say this is a supported scenario... but I have never had a ton of luck with Dynamic IP's on VoIP service.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Hello there,
    This is supported but we do not recommend it for production systems. The way to go is with static IP as always.
    Please note that with a dynamic IP setup there will be down time as the DNS update process takes some time and we do not control all the DNS servers as you can understand.
    And we can only do this if during the installation you selected a 3CX FQDN and DNS managed by 3CX.
  4. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    DnsQueryEx: 3cx FQDN
    Hi!
    Maybe it should be recommended to use Google ones? Or even option in SBC to select which to use?
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,379
    84
    Using the Google DNS servers would most likely reduce the downtime as you would not have to wait for the DNS propagation process, however there would still be some downtime until the 3CX Server updates the DNS entry.
  6. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    3cxWin10phone custom DNS
    Even better if there could be prov. parameter which would indicate that 3CXphone should use your server like ns1.3cx.com(bypass systems one)?
  7. mobycom
    Apr 4, 2008
    16
    Hi, what TTL do you use if we have dynamic? It looks like its 6 hours?
  8. andreaschr
    Oct 26, 2015
    91
    6
    Hi mobycom
    Correct is 6 hours for 3CXPBX , standard , pro License and
    5min for Enterprise License.
