3cx free & linksys spa901
Discussion in '3CX Phone System - General' started by art83, Feb 7, 2008.
  1. art83
    Feb 7, 2008
    hy all...
    I've bought 4 spa901, and i want to configure these with this method:
    one telephone only receive (TELEPHONE A) and the other 3 (TELEPHONE B, C, D) only call A.
    the most important features is: whenever i raise up the phone, automatically it call the telephon A, whitout i press keys...
    it's possible??? i hope and i think yes!! plese help me!
    ps: now the telephones B, C, D just call A but if i press the number of telephone A!
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    Some phones have functions like auto dial. If I'm right the grandstream. Maybe the linksys does too.
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    yes its possible
    First of all, make the extensions on 3cx and configure them on each phone then you will have to do this
    No need to touch on Telephone A configuration
    On telephone B,C,D you go to EXT1 tab and under dialing rules you should have something like
    (*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
    now, you will have to add "P3<:8000>" (without the ") to the end it should show something like
    (*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.|P3<:8000>)
    now P3 <- this number will be the amount of seconds it will take the phone to dial the number you want after you lift the handset
    the number insice <:8000> will be the extension that the phone will call
    So, Phone A - Ext 1000
    Phone B - Ext 2000
    Phone C - Ext 3000
    Phone D - Ext 4000
    on Phone B,C,D you should have something like (*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.|P3<:1000>)
    With this it would take 3 seconds to call to extension 1000
    Hope that helped
    Cheers
