3CX Free up to 30 User /max. 4 par. Calls/
Discussion in '3CX Phone System - General' started by 3cxisti, Dec 11, 2012.
  1. 3cxisti
    Dec 11, 2012
    24
    could this PC Ok for me:
    http://www.amazon.de/Atom-D2700-DualCore-M%C2%B5-Style-fanless/dp/B007QN6DY6/ref=cm_cr_pr_product_top
    I would use Windows 7 32bit as OS.
    The system would operate behind NAT (protected by pfSense Firewall).
    The office has ADSL (50Mbits Down and 2Mbits Up)
    The clients are connected via OpneVPN.
    User Codec G711.
    1Mbits would be reserved for VoIP with pfSense-QoS.
    Thank you very much confirming if it is OK.
    Best Regards,
    I.
    10,869
    304
    For a small set-up, that should work fine. The bigger drain on resources is the use of Voicemail (playback/recording), or any time that audio has to pass through the PBX/ transcoding, queues, or updating set status to myphone. The most of the time, once a call has been established, the PBX drops out of the picture.
    There have been a number of posts, and some Blogs about using small Atom based PC's to run 3CX.
    http://www.3cx.com/blog/voip-howto/atom-processor-n270-benchmarking/
    That was on an older Atom Processor, the one you are considering at is even better.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    803
    45
    I am using the Shuttle Barebone XS35V3, D2700 Atom, 4GB mem (3,24GB avail), 60GB SSD.
    It runs Win7 HP 32bit SP1, 3CX v11 SP2 with 8SC, 4 external and 7 internal extensions without any problem.
    Read also the comments at hhttp://www.3cx.com/docs/recommended-ha ... s-for-3cx/ - UPDATED LINK
    I hope it answers your question.
  4. 3cxisti
    Dec 11, 2012
    24
    Thank you very much for confirming my setup.
    It sounds good. :)
    One Question to IP... Is it a must to have a static IP or it would sufficient as well to use DynDNS or anything like this?
    We have some domains at the german provider Strato. I think they provide something like Dyndns as well.
    I.
  5. complex1
    Jan 25, 2010
    803
    45
    What ever you want.
    It runs fine on static-IP as well with DyDNS. (I use dyndns.org)
