3CX Freez with Kaspersky Anti-virus
Discussion in '3CX Phone System - General' started by meshad, Aug 12, 2009.
  1. meshad
    Aug 5, 2009
    41
    i can not play with 3CX system while runing Kaspersky Anti-virus. after close Kaspersky Anti-virus ok.
    in 3CX right side corner always shows busy status.
  2. houston
    Jul 21, 2009
    40
    Have you told Kaspersky to exclude the 3CX directories?
    I would also expect a full scan to affect voice quality, might want to make sure it's scheduled for the wee hours of the morning.
  3. meshad
    Aug 5, 2009
    41
    3CX is excluded on Kaspersky Anti-virus. but nothing happening.
  4. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Are you running it on XP or server 2003/2008?
    I run 3CX on a win2k3 R2 server with KAV for servers and have no performance problems.
  5. meshad
    Aug 5, 2009
    41
    3CX running on WinXP SP2. thanks for your commnets
  6. home
    Feb 25, 2009
    31
    I have 4 installations of 3CX and all are running Kaspersky on servers and terminals, I have not experienced any problems at all, are you sure its Kav causing the problem ?
  7. meshad
    Aug 5, 2009
    41
    im sure this problem create KAV. but i can recv and cal. after i close KAV busy indication (rounded arrowon right side corner) vanished and then can play on 3CX
  8. meshad
    Aug 5, 2009
    41
    Hey 3CX team!! what is this? is this part urs? im sure not
  9. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Someone has posted the "accounting" folder.
  10. houston
    Jul 21, 2009
    40
    Hmm, well, the only other thing that comes to mind is that you are using one of the Kaserpsky versions with a firewall, and that you've told it to block 3cx, or some component of 3cx. One of those occasional "Allow/Disallow" questions answered the wrong way.
    Uninstall Kaspersky, run the damanged installation removal tool, then reinstall.
    http://support.kaspersky.com/faq/?qid=208279463
  11. meshad
    Aug 5, 2009
    41
    some how now its fixed. now 3CX working with KAV.
    I added as trusted application in KAV. I added this on before also but that time it’s not working. Maybe its effect after sometimes or after restart OS
    Thanks to everybody for replaying.
