3CX Gateway for Skype help??
Discussion in '3CX Phone System - General' started by duanedtp, Oct 13, 2010.
  1. duanedtp
    Oct 13, 2010
    I'm having trouble making calls via skype gateway. The 3cx Gateway for Skype monitoring software shows that the call has been initiated "calling 347*********" then drops and goes back on the hook. Please help
    Here are both the gateway logs and 3cx server logs=
    Gateway
    00:37:21:406 - Info : Slave channel [duane.barker27] has been registered
    00:37:21:406 - Info : - registered slave channels: [duane.barker27]
    00:37:33:796 - Info : Incoming call from PBX ringing
    00:37:33:812 - Info : Outbound call requested
    00:37:33:812 - Info : Creating a Skype call to account [13476685565]
    00:37:33:875 - Info : Call (skypeid 7885) created for account [13476685565]
    00:37:33:890 - Info : Port check - Port [192.168.1.2:22500] is free
    00:37:33:984 - Info : Call (skypeid 7885) identified, [Duane Barker] calls [13476685565]
    00:37:34:000 - Info : Call (skypeid 7885) identified, [Duane Barker] calls [13476685565]
    00:37:34:015 - Warning : Slave channel [duane.barker27] has been removed
    00:37:34:015 - Info : - registered slave channels: []
    00:37:35:312 - Info : Call (skypeid 7885) has been ended by Skype, reason: finished [misc. error]
    00:37:35:328 - Info : PBX call has been ended by PBX
    00:37:35:359 - Info : Slave channel [duane.barker27] has been registered
    00:37:35:359 - Info : - registered slave channels: [duane.barker27]
    00:37:44:859 - Info : Incoming call from PBX ringing
    00:37:44:859 - Info : Outbound call requested
    00:37:44:859 - Info : Creating a Skype call to account [13476685565]
    00:37:44:921 - Info : Call (skypeid 8045) created for account [13476685565]
    00:37:44:921 - Info : Port check - Port [192.168.1.2:22500] is free
    00:37:45:046 - Info : Call (skypeid 8045) identified, [Duane Barker] calls [13476685565]
    00:37:45:078 - Info : Call (skypeid 8045) identified, [Duane Barker] calls [13476685565]
    00:37:45:125 - Warning : Slave channel [duane.barker27] has been removed
    00:37:45:125 - Info : - registered slave channels: []
    00:37:46:640 - Info : Call (skypeid 8045) has been ended by Skype, reason: finished [misc. error]
    00:37:46:656 - Info : Slave channel [duane.barker27] has been registered
    00:37:46:656 - Info : - registered slave channels: [duane.barker27]
    00:37:46:656 - Info : PBX call has been ended by PBX
    3CX Server (Same machine_ WinXp)
    00:37:46.765 [CM503016]: Call(6): Attempt to reach <sip:3476685565@192.168.1.2> failed. Reason: Reason Unknown
    00:37:46.765 [CM503003]: Call(6): Call to sip:13476685565@127.0.0.1:6060 has failed; Cause: 200 OK; from IP:127.0.0.1:6060
    00:37:45.062 Active calls counted toward license limit: [6]
    00:37:44.968 [CM505002]: Gateway:[SkypeOUT] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10001@127.0.0.1:5060]
    00:37:44.968 [CM503002]: Call(6): Alerting sip:10001@127.0.0.1:6060;rinstance=ae366a5e046d77da
    00:37:44.828 [CM503025]: Call(6): Calling PSTNline:13476685565@(Ln.10001@SkypeOUT)@[Dev:sip:10001@127.0.0.1:6060;rinstance=ae366a5e046d77da]
    00:37:44.796 [CM503004]: Call(6): Route 1: PSTNline:13476685565@(Ln.10001@SkypeOUT)@[Dev:sip:10001@127.0.0.1:6060;rinstance=ae366a5e046d77da]
    00:37:44.781 [CM503010]: Making route(s) to <sip:3476685565@192.168.1.2>
    00:37:44.781 [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CSipSimple] PBX contact: [sip:101@192.168.1.2:5060]
    00:37:44.750 [CM503001]: Call(6): Incoming call from Ext.101 to <sip:3476685565@192.168.1.2>
    00:37:35.406 [CM503020]: Normal call termination. Reason: Terminated
    00:37:35.406 [CM503016]: Call(5): Attempt to reach <sip:3476685565@192.168.1.2> failed. Reason: Reason Unknown
    00:37:35.406 [CM503003]: Call(5): Call to sip:13476685565@127.0.0.1:6060 has failed; Cause: 200 OK; from IP:127.0.0.1:6060
    00:37:33.921 [CM505002]: Gateway:[SkypeOUT] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:10001@127.0.0.1:5060]
    00:37:33.921 [CM503002]: Call(5): Alerting sip:10001@127.0.0.1:6060;rinstance=ae366a5e046d77da
    00:37:33.734 [CM503025]: Call(5): Calling PSTNline:13476685565@(Ln.10001@SkypeOUT)@[Dev:sip:10001@127.0.0.1:6060;rinstance=ae366a5e046d77da]
    00:37:33.656 [CM503004]: Call(5): Route 1: PSTNline:13476685565@(Ln.10001@SkypeOUT)@[Dev:sip:10001@127.0.0.1:6060;rinstance=ae366a5e046d77da]
    00:37:33.640 [CM503010]: Making route(s) to <sip:3476685565@192.168.1.2>
    00:37:33.625 [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CSipSimple] PBX contact: [sip:101@192.168.1.2:5060]
    00:37:33.593 [CM503001]: Call(5): Incoming call from Ext.101 to <sip:3476685565@192.168.1.2>
