3CX Gateway for skype install problem
Discussion in '3CX Phone System - General' started by big_col, Aug 4, 2010.
  1. big_col
    Aug 4, 2010
    I have been trying to install the skype gateway but i get the error Disk1.cab is corrupt half way into the install. If you ignore you get an error code 2350 unexpected error installing the package. The main system installed ok. I have tried redownloading but the error is still there. I am using XP as the operasting system and 4.2.0.169 skype
    Colin
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    If you want you may take a copy of my (well running) 3CX Gateway for Skype file at http://www.c2service.nl
    Beneath the Logo you see “Gateway”, right click, save as, and save it in the desired directory.
    If the install of this copy also result in an error then there must be something else going on.
  3. schmag
    Apr 28, 2009
    Hello
    I have the same problem, but my OS is win7 32 bits , anyone has any solution that can help?
    Best regards,
