3CX Gateway for skype on SBS 2008 (Server 2008)
Discussion in '3CX Phone System - General' started by burukhtan, Aug 8, 2009.
  1. burukhtan
    Aug 8, 2009
    Hallo,
    We install 3CX Gataway for Skype on Windows SBS08.
    While configuring we get an error: cannot add user account (3cxskypeacc01) to the group 3cx.....!
    Has someone installed 3CX-Skype gateway on the Server 2008?
    Thank you.
    Here is the log:
    5:55:24:857 - Info : Channel listener running on [127.0.0.1:5544]
    15:55:24:857 - Info : Starting PBX server checker on [192.168.10.4:5060], checking at every [2000] msec
    15:55:24:857 - Info : Starting Skype server checker on [www.skype.com:80], checking at every [2000] msec
    15:55:24:857 - Info : Starting service checker, checking at every [500] msec
    15:55:26:738 - Info : Current user profile successfully loaded
    15:55:40:063 - Info : Port check - Port [localhost] is free
    15:55:40:068 - Info : Attempting to create a new computer Skype gateway account
    15:55:40:455 - Info : Account [3cxskypeacc01] sucessfully created
    15:55:40:551 - Info : Account group [3CXSkypeGatewayAccounts] successfully created
    15:55:40:570 - Error : Cannot add account [3cxskypeacc01] to group [3CXSkypeGatewayAccounts]:
    Cannot create or delete the local group account, because it does not exist. (0x0000056B)
    15:55:41:482 - Error : Cannot logon to computer account [1] for channel [10000], channel will be disabled!
    15:55:45:396 - Info : Port check - Port [localhost] is free
    15:55:45:402 - Info : Attempting to create a new computer Skype gateway account
    15:55:45:424 - Info : Account [3cxskypeacc01] already created
    15:55:45:425 - Error : Cannot logon to computer account [1] for channel [10000], channel will be disabled!
    15:55:53:890 - Info : Current user profile successfully loaded
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Have you tried manually adding the skype user to the skype group to see if it starts working?
  3. theros
    Aug 11, 2009
    We are having the Same Problem....
    Have you managed to figure it out yet?
    Any help will be appreciated!
    Roger Theron
    Theros ICS - 3CX Partner
    http://www.mytheros.net
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    Hi burukhtan, theros
    Your servers are somehow (Primary) Domain Controllers?
    Regards
    vali
  5. theros
    Aug 11, 2009
    Hi there,
    yes, it would be.
    regards
    Roger
  6. Vali_3CX
    Dec 12, 2008
    1,527
    71
    Hi, Roger
    Not a good news this one - we had a quite old report about a similar issue, and we found that this error (its description you saw is provided by the system, not by us) is related to this "attribute", Domain Controller, of the OS running the gateway. At this moment we don't have a reason of this behavior and, therefore, not a fix yet. When one will be available, we will announce it.
    Regards
    vali
  7. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    I run 3CX on a PDC with Exchange 2010 Beta.
    In order to get this working you need to install 3CX before setting up the domain controller, or You will need to login to the server as a local user with admin privileges.
    You may need to right click and Run as Administrator.
