3CX Gateway
Discussion in '3CX Phone System - General' started by spring, Sep 6, 2016.
  1. spring
    Nov 20, 2014
    53
    Hi, is it possible to load balance 3CX gateway? like Patton?
    10,567
    246
    You might want to explain, in a bit more detail, about what you would like to achieve.
  3. spring
    Nov 20, 2014
    53
    Thanks you for your response Leejor,
    I want to know if can load balance Patton gateway?
    EX: E1 connected to two patton gateway and if one patton down E1 still can call.
  4. leejor
    10,567
    246
    To clarify...you have two E1s, each connected to a Patton gateway? If so, I assume they are from the same provider and each has their own "D" channel, (each a separate PRI), rather than one being a second E1, as a part of a larger trunk group? Is this correct?
    Or, are you trying to use one E1, and "share" it between two gateways?
  5. spring
    Nov 20, 2014
    53
    Hi Leejor,
    Yes the plan is to use one E1 and shared with two gateways.
