3CX going cold and dead once a week
Discussion in '3CX Phone System - General' started by qaisdev, Apr 7, 2008.
  1. qaisdev
    Apr 7, 2008
    33
    I wanted to ask that if anyone is having same problem of 3cx going dead at lease once a week.
    Nothig is error logs just all of a sudden all the phones stop working.Is there something that i am missin?
    After restarting the 3cx services or restarting system all work fine.
    3cx Ver no 5.1
    Vegastream 400
    Polycom 330 IP Phones
    Any help will be really appreciated.
    Kind Regards
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Bandaid fix is to schedule a service restart. What OS and what version of 3CX are you using? I've found Server 2003 to be more stable than XP. XP works but when the is constant use of the PBX it seems to have some issues. Server is handling it well.
  3. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    It would be interesting to look at this a bit more closely, and the best way would be for you send us logs.
    Please note that a system restart will clear all logs, so the correct time to collect the logs is when the problem is current.
    If you could set the PBX logging to verbose it would alse help to give us details of what was happening at the time that the PBX became unresponsive.
    Note however that verbose logging can consume significant HDD space so ensure this is not an issue before starting.
    Thanks and Regards
    Kevin
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,973
    283
    Please let us know what exact build number you are using. I suspect you are using an older build. Later builds should not have this.
  5. qaisdev
    Apr 7, 2008
    33
    Thx for the replies..
    I have enables the verbose logging and will post the logs as soon as it will crash again.
    Regards
    Qais
  6. qaisdev
    Apr 7, 2008
    33
    Last night i upgraded to the latest build.
    I hope it will do the trick.
    Will keep posting the progress.
    Kind Regards
  7. qaisdev
    Apr 7, 2008
    33
    Hi Matt,
    My 3CX is installed on win 2003.I upgraded to the latest version and since then it is working allright.
    But it has been only couple of days since i upgraded , i will have to wait a week at lease to give any reviews about
    this new bulid.I hope it does not breaks up.
    Cheers
  8. darrellchapman
    Nov 26, 2007
    268
    We use to have the same exact problem. No information was provided in the logs (even in verbose mode). Everything just simply froze. However, since upgrading to build 4393 everything has been running smoothly.
  9. Ralph
    Ralph Member
    Jun 28, 2007
    417
    We have a problem that may be similar. Once a week the lines seem to go dead. They appear registered but no one can call out. Sometimes incomming calls are ok and other times no one can call in either. When we restart the server, and in the case of BroadVoice change proxies, everything is ok for another week or so. This is happening on multiple servers and needless to say clients are getting a bid frustrated with having to restart their servers all the time.
    Using the followng:
    3CX Phone System v5.1.4078.0
    Windows Server 2003 Enterprise Ed. SP2
    1 gig of ram
    40 gig HD. (36 gig free)
    Any help appreciated.
    Thanks again
  10. Nick Galea
    Jun 6, 2006
    1,973
    283
    You need to upgrade to the latest version, you are running an old version.... I am sure that will resolve these problems.
  11. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good morning Nick,
    We upgradedto the latest version yesterday. I'll let you know how it goes.
    Take care
  12. qaisdev
    Apr 7, 2008
    33
    Hi Ralph,
    Yea after upgrade it seems to be stablised.It has not broken up since then.I hope it stays okay.But there are some issues to address.
    1)Call pickup does not work .(9100 + extention no)
    2)One of the party is not able to hear when a call is transferred to external number(i.e)(external 1-3CX-external 2) = (External 1 - External 2)
    Rest all seems to be okay.
    Kind Regards
    Qais
  13. Nick Galea
    Jun 6, 2006
    1,973
    283
    Hi Ralph, Qais
    We are aware of the call pick up problems. Our apologies for that. A patch will be issued (4393 will be easily upgradeable to this patch simply by running the check for updates application) over the next few days. We will check the other one, what gateway or voip provider are you using.
  14. qaisdev
    Apr 7, 2008
    33
    We are using vega 400 with polycom ip330 hand sets.
    I will be waiting for the new patch.
    Kind Regards
    Qais
  15. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Good morning,
    Glad to hear about the patch. Already getting questions about picking up calls :shock: and the transfer to external line functionality is very popular for cells etc. The sooner these get fixed the easier my life becomes :lol:
    We are 100% VoIP using BroadVoice and Vitelity.
    Take care
  16. qaisdev
    Apr 7, 2008
    33
    Thx for the latest build.It solved most of my problems.
    Kind Regards
    Qais
  17. Nick Galea
    Jun 6, 2006
    1,973
    283
    Thanks for the feedback! So latest build 4510 has been stable in your environment, with few stuck calls and so on?
  18. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    It's been fairly stable for me - but right now my extension is shown as calling - I know it isn't.
    I can actually call (and the call will complete), and I can receive calls successfully - and the status will update to show that I'm in a call, but after the call has finished, it drops back to calling.
    I think the reason it is stuck in calling is that I hung up on voice mail: I called a colleague's extension, got voice mail, and hung up. I then fired up the line status page to see who he was on the phone to (as my call was quite urgent, and I was going to call him on another extension if he wasn't on the phone to an important client), and that's when I saw my phone was still shown as calling.
    So, I suspect that sometimes internal calls that get answered by voice mail can leave an extension stuck in calling state according the line status - but otherwise working.
