3CX Grandstream trunk connectivity
Discussion in '3CX Phone System - General' started by 3CX4COAX, Jun 21, 2010.
  1. 3CX4COAX
    Jun 21, 2010
    I am using a free 3CX version 8 to test out the system. I have registered and used extensions successfully with the system, but I am having difficulty registering the trunk with the Grandstream GXW4108 FXO Gateway.
    Is that a feature of the free version not to connect to outside lines or is something else misconfigured?
    If this problem has been addressed somewhere else please point me in the right direction.
    thanks,
  2. carolinainnovative
    May 4, 2009
    369
    6
    Make sure you follow the instructions here:
    Forum rules - Read to get answers
    on how to get help and post the logs as instructed. Before you post them, please make sure you put 3cx in verbose mode by going to the management console Settings > Advanced > verbose mode and restart 3CX services.
    Then use code and /code tags to post the log here.
    Also - per the above post, make sure you read the various support faqs and make sure you've followed the setup described under supported devices for the GXW4108. It is listed as a supported device. See setup instructions HERE:
    http: //www.3cx.com/voip-gateways/Grandstream-GXW-41044108/ NO LONGER AVAILABLE Configuring Grandstream GXW-4104 / GXW-4108 Gateway for 3CX Phone System
