3cx group pickup caller ID
Discussion in '3CX Phone System - General' started by Jimbo_, Jul 10, 2014.
  1. Jimbo_
    Jan 31, 2013
    18
    We have a problem with caller ID's when using group pickup. Here is the scenario:
    Caller A rings B
    B is away from desk so C picks up the call using *20*
    A's handset still shows the caller ID as B, and not the now C as it should
    Is there a way around this? It would be good to see who has picked up the call from the original caller
    Jimbo
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Unfortunately this is not possible, it will always show the original callee.
    I'd suggest posting this as a feature request on our 3CX Ideas site : http://3cx.com/ideas
