3CX health status monitoring
Discussion in '3CX Phone System - General' started by lci, Apr 28, 2014.
  1. lci
    lci
    Feb 18, 2014
    Hi, I have deployed 3cx system in my company.
    I'm wondering how to monitor the status of 3cx system.
    I have Nagios that checks health status of many services in my network.
    Maybe I could use it also to monitor if 3cx is ok.
    I had a sittuation when my firewall hung and it didn't forward traffic to 3cx machine, so our phones didn't ring. T
    hank you for any suggestions.
    Regards
    Lci
    11,077
    324
    3CX has the ability to send an email when one or more VoIP providers(or bridge trunks) fail to register, which I would assume would be the outcome if a firewall (between 3CX and the outside world) were to fail.
    If that doesn't work for you, then I'm not sure what the use of monitoring tools will buy you, as it sounds as though 3CX was working just fine, just not receiving calls.
  3. lci
    lci
    Feb 18, 2014
    Thank you leejor, I will try to configure this feature.
    This should solve my problem.
    Thank you! :)
