3CX HotDesking - File Not Found
Discussion in '3CX Phone System - General' started by Micahel, Nov 13, 2017.
  1. Micahel
    Aug 4, 2017
    50
    I am trying out the new hotdesking feature in the latest service pack upgrade to version 15.5 (yes i know it is still in beta at this point in time)
    I have managed to register a Yealink T48G as a hotdesking phone, but when even i go to log into an extension on the phone i just get the message "File not Found".
    I found on this guide https://www.3cx.com/docs/hot-desking/ that i have to upgrade the system prompts to make it work.
    I have upgraded all the prompts and i am still getting this message.
    Am i missing something?
    Any help will be much appreciated.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,354
    274
    Hello @Micahel
    Are you on windows or linux? Have you tried restarting the services of the PBX to see if that works?
  3. Micahel
    Aug 4, 2017
    50
    I am on Linux and after i downloaded all the updates for the system prompts it didn't work so i restarted all services but still have the same issue.
  4. YiannisH_3CX
    May 10, 2016
    4,354
    274
    What prompt set are you using? Do you have a custom prompt set or using one of the provided prompt sets?
  5. Micahel
    Aug 4, 2017
    50
    I was using a custom Australian prompt set but ended up changing it back to default standard English prompt set and i am still having the same result.
  6. YiannisH_3CX
    May 10, 2016
    4,354
    274
    Please check your inbox as i have sent you a p.m.
  7. Micahel
    Aug 4, 2017
    50
    So you were able to download the files from another 3CX server that has the latest update?
    I will try this to see if that will also work for me.
  8. Micahel
    Aug 4, 2017
    50
    I tried copying the prompt set from another tenancy but my pbx wouldn't recognize the log in and out files.
    I deleted the entire English prompt set and re-downloaded it and now i have the correct files.
    The problem i am having now is that the phone isn't loading the user i am logging in with.
    On the screen it still says HD00001, however in the management console under the hotdesking tab it says i am logged into the hotdesking phone.
    Any thoughts on this?
  9. StefanW
    Jun 2, 2009
    1,195
    78
  10. Micahel
    Aug 4, 2017
    50
    Hello Stefan,
    Not sure if you noticed but in my original post you can see i have already mentioned i have followed those steps from that link.
    Anyway....
    I have now upgraded to the stable version of SP2 this morning.
    I have also factory reset the Yealink T48G and deleted the hot desking extension and recreated. I have done this just to start fresh and it still isn't working.
    I now think i know why this isn't working.
    I am using an SBC programmed on a Raspberry Pi 3. I have had a quick look on the internet and i can see that the PnP provisioning method will not work through a raspberry pi SBC but will work through a Windows SBC.
    Does anyone know if there is a way to get the PnP provisioning method to work on the raspberry pi 3??
  11. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    PNP will work on raspberry pi. Ensure you have the latest update.
    As for the custom Australian prompset - When you copied it, the prompt files for HD were not there.
    We incremented the version online to force a standard English prompt set update. Do that update. Then recreate the prompt set from that version. There will be 4 added files. Those are the ones you need.
